Slow WinSCP startup
CopyBot
Afghanistan
Slow WinSCP startup
i have a fast PC but still WinSCP needs 3 seconds to start up. Since i start WinSCP more often it would be nice if it would start up faster. Is there an option which lets it start up faster?
Cheers and thanks in advance
CopyBot
Re: Slow WinSCP startup
Do you mean that it takes 3 second before the Login dialog appears?
What is your PC spec? Just for comparison with mine.
CopyBot
Afghanistan
thanks for answer, prikryl.
yes i meant the time before the Login dialog appears.
But now, the WinSCP dialog appears fast, i dont know why.
