how to compile version 5.0?
doug
slovakia
I'm trying to compile newest winscp from source, but I have some problems.
first problem was that builder 2010 is missing mfc headers and build fails at building filezilla, I solved this by copying mfc headers from borland 6.0
another problem was that during compilation of winscp.exe it was missing ssleay32.lib, I solved this by adding lib\ path to winscp.exe project library directories
now I am stuck at linking winscp.exe which fails with [ILINK32 Error] Fatal: Unable to open file 'UAFXCW.LIB'. there is no uafxcw.lib in builder 2010 or 6.0 and if I try to use one from visual studio it also fails since the library is not compatible with builder.
So how can i get working uafxcw.lib or get winscp compiled correctly?
also the readme file mentions "To build WinSCP from source by yourself, modify and use 'build.bat' in root folder of source code package." but there is no build.bat in source archive
thanks for any help
Re: how to compile version 5.0?
https://winscp.net/tracker/724
Regarding MFC/ATL (UAFXCW.lib), see <invalid hyperlink removed by admin>
This link will be included into the readme file in the next release.
doug
slovakia
with 5.0.1 I was able to successfully compile winscp without ftp support if I defined NO_FILEZILLA
problems:
in source archive the readme_mfc is the same file as readme
using the directions from the embarcadero forum I am able to compile only debug ansi version of mfc library, it fails if I try to build nondebug or unicode version
sfda
what is correct flags to compile no debug, unicode version?
whaen i try to build no debug uafxcw.lib,
i got internal backend error c10862,
bartool.cpp line 1883.
can i GET CORRECT UNICODE LIB IF add ONLY UNICODE=1 TO MAKE OPTION FLAGS?
My fault. I'll fix it.
Actually my readme is for debug only too. I do not remember why anymore. Will check.
I have updated the readme to include all code changes necessary to compile MFC using C++ Builder 2010
This readme will be included in the next release.
Hi Prikryl,
Could you please share the mfc source and include files from BCB6?
Thanks.
Stoval
Hi Prikry1,
I've managed to find the mfc sources, but it looks that the sources file might be different from yours as I have the following issues:
1)No suitable place for
- add the following line to dumpstak.cpp at line 141
TARGDEFS=/D_UNICODE /DUNICODE
2)There is no atldbcli.h in source\mfc directory, I searched and found one in C:\Program Files (x86)\Embarcadero\RAD Studio\7.0\include\atl
3) There is no arccode.cpp but a arccore.cpp under source\mfc
4) bartool.obj,ctlcore.obj, ctlnownd.obj, dockcont.obj, viewprev.obj and dockstat.obj have to be removed in borland.mak
5) My dumpstak.cpp has 386 lines in total, so place for
- add the following line to dumpstak.cpp at line 432
#define _tclen(__a) (1)
The good news is that UafxcW.lib is created.
When I tried to run the build.bat, I have the following error:
F:\Share\winscp505source>build.bat
Microsoft (R) Build Engine Version 4.0.30319.1
[Microsoft .NET Framework, Version 4.0.30319.239]
Copyright (C) Microsoft Corporation 2007. All rights reserved.
Build started 16/12/2011 3:07:58 PM.
Project "F:\Share\winscp505source\WinSCP.groupproj" on node 1 (clean;Build targ
et(s)).
Project "F:\Share\winscp505source\WinSCP.groupproj" (1) is building "F:\Share\w
inscp505source\packages\Moje.cbproj" (2) on node 1 (Clean target(s)).
F:\Share\winscp505source\packages\Moje.cbproj : error MSB4057: The target "Clea
n" does not exist in the project.
Done Building Project "F:\Share\winscp505source\packages\Moje.cbproj" (Clean ta
rget(s)) -- FAILED.
Done Building Project "F:\Share\winscp505source\WinSCP.groupproj" (clean;Build
target(s)) -- FAILED.
Thanks for your help.
Regards,
Stoval
Build FAILED.
"F:\Share\winscp505source\WinSCP.groupproj" (clean;Build target) (1) ->
"F:\Share\winscp505source\packages\Moje.cbproj" (Clean target) (2) ->
ean" does not exist in the project.
0 Warning(s)
1 Error(s)
Time Elapsed 00:00:00.70
