Far plugin dos'n connect to winsshd.
Beacon
Far plugin 1.1 dos'n connect to winsshd. Authentication failed. Connect to Linux sshd success.
WinSCP 3.5 connect to winssshd success.
Re: Far plugin dos'n connect to winsshd.
Can you try 3.4.2. FAR plugin 1.1 hase same SSH core and 3.4.2. But I'm not aware of any significant change in SSH implementation between 3.4.2 and 3.5.
Beacon
WinSCP 3.4.2 connect to winsshd success. Far plugin 25 connect failed, 1 connect success :(
Far plugin:
. WinSCP Version 1.1.0 (Build 54)
. Login time: 13 .... 9:48:12
. Session name: Referent
. Host name: www.referent.ru (Port: 22)
. User name: malevanny (Password: Yes, Key file: No)
. Transfer Protocol: SFTP (SCP)
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes
. Ping interval: 0 sec (0 = off); Timeout: 15 sec
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: none
. Shell: default, EOL: 0
. Local directory: default, Remote directory: home, Update: No, Cache: Yes
. Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. Looking up host "www.referent.ru"
. Connecting to 212.188.13.163 port 22
. Server version: SSH-2.0-1.35 sshlib: WinSSHD 3.11
. We claim version: SSH-2.0-WinSCP-FAR-release-1.1
. Host key fingerprint is:
. ssh-dss 1024 79:4f:ba:4c:d9:8d:98:74:78:86:52:37:92:86:93:81
. Initialised zlib (RFC1950) compression
. Initialised zlib (RFC1950) decompression
. Attempt to close connection due to fatal exception:
* Authentication failed.
* (EAccessViolation) EAccessViolation
. Closing connection.
WinSCP:
. WinSCP Version 3.4.2 (Build 197)
. Login time: 13 .... 9:49:51
. Proxy: none
. We claim version: SSH-2.0-WinSCP-release-3.4.2.197
! Using username "malevanny".
. Session password prompt (malevanny@www.referent.ru's password: )
. Using stored password.
. Sent password
. Access granted
. Opened channel for session
. Started a shell/command
. Using SFTP protocol.
> Type: SSH_FXP_INIT, Size: 5, Number: -1
< Type: SSH_FXP_VERSION, Size: 5, Number: -1
. SFTP version 2 negotiated.
. Getting real path for '.'
> Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< Type: SSH_FXP_NAME, Size: 29, Number: 16
. Real path is '/d:/'
. Listing directory "/d:".
> Type: SSH_FXP_OPENDIR, Size: 12, Number: 267
< Type: SSH_FXP_HANDLE, Size: 10, Number: 267
> Type: SSH_FXP_READDIR, Size: 10, Number: 524
< Type: SSH_FXP_NAME, Size: 1560, Number: 524
> Type: SSH_FXP_READDIR, Size: 10, Number: 780
< Type: SSH_FXP_STATUS, Size: 9, Number: 780
< Status/error code: 1
> Type: SSH_FXP_CLOSE, Size: 10, Number: 1028
< Type: SSH_FXP_STATUS, Size: 9, Number: 1028
< Status/error code: 0
. Startup conversation with host finished.
octy
One more log
I've got the same problem with SSH 3.2.0 on linux, FAR 1.70beta5. Note that all is ok with last versions of WinSCP. -:(=
See the log below:
. Login time: 3 ╠рЁЄ 2004 у. 0:47:44
. Session name: session1
. Host name: 193.#.#.# (Port: 22)
. User name: octy (Password: Yes, Key file: No)
. SSH protocol version: 2 only; Compression: No
. Ciphers: des,3des,blowfish,aes,WARN; Ssh2DES: No
. Proxy: none
. Local directory: default, Remote directory: /usr1/home/octy, Update: Yes, Cache: Yes
. Clear aliases: Yes, Unset nat.vars: No, Resolve symlinks: Yes
. Looking up host "193.#.#.#"
. Connecting to 193.#.#.# port 22
. Server version: SSH-2.0-3.2.0 SSH Secure Shell (non-commercial)
. ssh-dss 1024 fd:49:ad:ea:34:ba:90:3c:10:7c:d4:27:47:f3:98:e9
. Initialised triple-DES client->server encryption
. Initialised triple-DES server->client encryption
