WinSCP Scheduled Task Only Works when RDP is Connected
mrichman
United States
I have a console app (VB.NET) very similar to the example code presented on this site. When run interactively, it can upload/download via SFTP without issues. When run via a Scheduled Task, it runs silently without issues. However, when my RDP session to the server disconnects, the Scheduled Task runs, but WinSCP fails with error messages like this:
The WinSCP executable appears to have crashed. Log file C:\Documents and Settings\MyServiceAccountName\Local Settings\Temp\tmp112F.xml does not exist.
Other times, the WinSCP.exe and WinSCP.com processes stay running and idle until I kill them.
Is there something special about running WinSCP from a console app running as a scheduled task that would cause this type of behavior?
Thanks,
Mark
seyed
Re: WinSCP Scheduled Task Only Works when RDP is Connected
I have sent you an email.
I have the below issue while running through .net on 2003 server. please advise.
The WinSCP executable appears to have crashed.Could not find the file C:\Documents and Settings\Admin\Local Settings\Temp\tmp112F.xml
How do you run WinSCP? Can you provide more details?
Seyed
we are using vb.net program to do the transmission.
I can able to connect the SFTP server and transmit the file. but finally i'm receiving this error.
please help me!!!
tsantony
did you resolved this case? if yes can you please share the solution?
we are also facing the same issue and we are using windows 2003 and vb.net
Thanks,
Mark
I would like to help both of you, but you need to provide some details. Please share your code/commandline you use to run WinSCP. Share any logs (set Session.DebugLogPath).
Alex23
I have a SQL Server Integration Services package where I use an execute process task to start WinSCP with a script file. In the SQL Server Agent I have a job scheduled to start the package. This workerd fine untill the sftp server was changed. Now the scheduled job only works when my pc is connected via remote desktop connection with the server which runs the job.
This is the content of my script file:
option batch abort
open sftp://<SFTP-Server>/ -hostkey=<key>
get /download/*.csv \\%computername%\Data_D$\Temp\*.csv
It would be realy great if anybody could help.
Alex
option batch abort
Did you update the host key?
Alex#23
Hi Martin,
thanks for the quick response. yes, I updated the host key.
I could resolve the problem. I found this on your site
"If there was no such site in current configuration storage (Windows registry in this case), mysession (as passed to open command) would be interpreted as host name and the log line would say:
Session name: mysession (Ad-hoc session)"
As I created the site for the new SFTP-server I had to realize, that I have no pemrission to set the "configuration storage" to "Windows registry". So I saved a custom INI-file which I think caused the problem. I asked my server admin to change the "configuration storage" to "Windows registry" and now it works again.
What I still doesn't understand is, that my log-file still has the following entry "Session name: KSIMDB@***.de (Ad-Hoc site)". I thought that "(Ad-Hoc site)" would no longer appear in the log.
Alex
You get that whenever the open command sets any additional options (on top of the stored site).
