need a "export connection"
hauser@...
just moved to a new computer.
I would love to be able to get my connections into the new installation.
Haven't found an easy way to do that!
biju
Re: need a "export connection"
Something like this is need!!
like save to a *.winscp file then double click it to open it
current solution
if u r using registry for settings, export registry key
HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2
if ini file find winscp3.ini file
and copy it to new computer
I think that storing configuration to INI file and transfering the INI file is exactly what you need. You may consider switching to INI file as an "export" of configuration.
