Memorizing directory location
ldpost
Trying to figure out how to "Save current directory as Connection directories". This feature is being used in WS_FTP and it is very convenient feature. Most of the time we need to move files from one fixed locations to the another location. So, can we memorize the directory location of the session? Thanks. LDPOST
Re: Memorizing directory location
You may specify default remote and local directory on Environment tab of login dialog. To save current directories (of opened session), you may use "Save" command from Session menu.
