Log only output of synchronization job
Hi all,
Is it possible to only log the output of the sync command.
I'm running:
And I only want the output of this command stored in a log file, so I can use it again in an email script.
So I only want to know what's been modified (del/copy etc) in the transfer, below is the part I need.
The
Anyone who can point me in the right direction.
Thanks!
Wouter
I'm running:
synchronize REMOTE -mirror -delete "c:\temp" /home/wouter/Temp
Comparing... Local 'c:\temp\2' => Remote '/home/wouter/Temp/2' Synchronizing... Local 'c:\temp' => Remote '/home/wouter/Temp' '/home/wouter/Temp/log.txt' deleted winscp>
The
/log with winscp.exe gives me way to much info.
Thanks!
Wouter
