WinSCP cmd-files not executable from 3rd party program
Hi at all..
someone here familiar with File-Watcher programs like "File Watcher Simple", "Directory Monitor" or similar Programs?
I spend many hours to get WinSCP scripts work with these Tools - no chance.
I created a cmd-file to load specific files beginning with
This works perfectly when started directly from Windows. No Problems!
I use a File Watcher Tool to watch, if new files are detected in my local download-directory to load them up right to my webspace.
For doing that all this Watching Tool provides similar "action"-possibilities, but obviously I don't find the right syntax to get things work.
Normally this Tools manage this "action" by two commands.
I tried:
(some Tools don't accept this syntax at all)
also I tried:
Application:
Argument:
I'm running out of ideas.. what can I try??
Sometimes I can see the console of
I hope you can help me.
Sincerely
Chris
Umsaetze_DE49501900000* + actual Date to my webspace.
- command: The Application you want to start
- command "Arguments" (whatever this means...)
I tried:
C:\Program Files\WinSCP\WinSCP.com /script="C:\Program Files\WinSCP\upload_fvb.cmd"also I tried:
Application:
Argument:
script="C:\Program Files\WinSCP\upload_fvb.cmd" (with or without slash at the beginning doesn't make a difference, so does quotes)
winscp.com shortly but it seems to crash right away and shut down very quickly, so I dont get informations what is going wrong.
Sincerely
Chris
