Transfer resume support .NET Library
Hello, I'm trying to configure the session options to enable transferresumesupport.
Here's my existing synchronisation script,
I've added the
https://winscp.net/eng/docs/library_transferresumesupport
Any help would be much appreciated, cheers in advance.
try { # Connect to the SFTP server $session.Open($sessionOptions) # Enabled transfer with resume support/to temporary filename for all files $transferOptions = New-Object WinSCP.TransferOptions # Synchronize local directory with remote directory (down and up) $synchronizationResult = $session.SynchronizeDirectories( [WinSCP.SynchronizationMode]::Remote, "$localpath", "$remotepath", $False ) # Check for synchronization errors $synchronizationResult.Check() # Print synchronization results foreach ($transfer in $synchronizationResult.Downloads) { Write-Host "Download of $($transfer.FileName) succeeded" } foreach ($transfer in $synchronizationResult.Uploads) { Write-Host "Upload of $($transfer.FileName) succeeded" } } finally { # Disconnect and dispose session $session.Dispose() }
$transferOptions = New-Object WinSCP.TransferOptions line, as you can see. But not sure exactly what the syntax should be for then enabling the ResumeTransferSupport transfer option
