resumesupport does not work
I use this script:
All
Here are the log:
I use this script:
option batch continue option reconnecttime 5 option confirm off option transfer binary open ftp://ftp-kassen:xxx@yyy.de -timeout=120 -passive=on lcd %1% cd /Payback/ #-- MW 04.09.24 -resumesupport=on integriert. Somit werden die Dateien zuerst mit .filepart hochgeladen und werden nach erfolgreichen Upload in #-- den Original Dateinamen umbenannt. Somit wird ein Herunterladen der Datei, während die Datei noch hochgeladen wird, verhindert put -resumesupport=on *.json close exit
*.json files are immediately uploaded to the server as *.json and not as *.filepart. What's wrong?
Here are the log:
. 2024-09-05 11:01:15.431 -------------------------------------------------------------------------- . 2024-09-05 11:01:15.433 WinSCP Version 6.3.4 (Build 14955 2024-06-17) (OS 10.0.19045 – Windows 10 Enterprise) . 2024-09-05 11:01:15.433 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\ . 2024-09-05 11:01:15.433 Log level: Reduced, Rotating after: 1000K, Keeping at most 5 logs . 2024-09-05 11:01:15.433 Local account: PR-DOM\martin . 2024-09-05 11:01:15.434 Working directory: C:\IT_Cash\payback . 2024-09-05 11:01:15.434 Process ID: 12736 . 2024-09-05 11:01:15.475 Ancestor processes: cmd, explorer, ... . 2024-09-05 11:01:15.477 Command-line: winscp.exe /script=pbputWV.scp /timeout=20 /logsize=5*1000K /log=LOG /loglevel=-1 /parameter N:\IT_Drink\Payback\test . 2024-09-05 11:01:15.478 Time zone: Current: GMT+2, Standard: GMT+1 (Mitteleuropäische Zeit), DST: GMT+2 (Mitteleuropäische Sommerzeit), DST Start: 31.03.2024, DST End: 27.10.2024 . 2024-09-05 11:01:15.479 Login time: Donnerstag, 5. September 2024 11:01:15 . 2024-09-05 11:01:15.479 -------------------------------------------------------------------------- . 2024-09-05 11:01:15.479 Script: Retrospectively logging previous script records: > 2024-09-05 11:01:15.479 Script: option batch continue < 2024-09-05 11:01:15.479 Script: batch continue > 2024-09-05 11:01:15.479 Script: option reconnecttime 5 < 2024-09-05 11:01:15.479 Script: reconnecttime 5 > 2024-09-05 11:01:15.479 Script: option confirm off < 2024-09-05 11:01:15.479 Script: confirm off > 2024-09-05 11:01:15.479 Script: option transfer binary < 2024-09-05 11:01:15.479 Script: transfer binary > 2024-09-05 11:01:15.479 Script: open ftp://ftp-kassen:xxx@yyy.de -timeout=120 -passive=on . 2024-09-05 11:01:15.479 -------------------------------------------------------------------------- . 2024-09-05 11:01:15.479 Session name: ftp-kassen@yyy.de (Ad-Hoc site) . 2024-09-05 11:01:15.480 Host name: transfer.yyy.de (Port: 21) . 2024-09-05 11:01:15.480 User name: ftp-kassen (Password: Yes, Key file: No, Passphrase: No) . 2024-09-05 11:01:15.480 Transfer Protocol: FTP . 2024-09-05 11:01:15.480 Ping type: Dummy, Ping interval: 30 sec; Timeout: 120 sec . 2024-09-05 11:01:15.480 Disable Nagle: No . 2024-09-05 11:01:15.480 Proxy: None . 2024-09-05 11:01:15.480 Send buffer: 262144 . 2024-09-05 11:01:15.480 UTF: Auto . 2024-09-05 11:01:15.480 FTPS: None [Client certificate: No] . 2024-09-05 11:01:15.480 FTP: Passive: Yes [Force IP: Auto]; MLSD: Auto [List all: Auto]; HOST: Auto . 2024-09-05 11:01:15.481 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes . 2024-09-05 11:01:15.481 Cache directory changes: Yes, Permanent: Yes . 2024-09-05 11:01:15.481 Recycle bin: Delete to: No, Overwritten to: No, Bin path: . 2024-09-05 11:01:15.481 Timezone offset: 0h 0m . 2024-09-05 11:01:15.481 -------------------------------------------------------------------------- < 2024-09-05 11:01:15.509 Script: Connecting to yyy.de ... . 2024-09-05 11:01:15.509 Connecting to yyy.de ... < 2024-09-05 11:01:15.775 220 ProFTPD Server (ProFTPD) [000.000.000.000] > 2024-09-05 11:01:15.775 USER ftp-kassen < 2024-09-05 11:01:15.814 331 Password required for ftp-kassen > 2024-09-05 11:01:15.815 PASS ***************** < 2024-09-05 11:01:15.901 230 User ftp-kassen logged in > 2024-09-05 11:01:15.901 SYST < 2024-09-05 11:01:15.941 215 UNIX Type: L8 > 2024-09-05 11:01:15.941 FEAT < 2024-09-05 11:01:15.981 211-Features: < 2024-09-05 11:01:15.982 AUTH TLS < 2024-09-05 11:01:15.982 CCC < 2024-09-05 11:01:15.982 CLNT < 2024-09-05 11:01:15.982 CSID < 2024-09-05 11:01:15.982 EPRT < 2024-09-05 11:01:15.982 EPSV < 2024-09-05 11:01:15.982 HOST < 2024-09-05 11:01:15.983 LANG C.UTF-8* < 2024-09-05 11:01:15.983 MDTM < 2024-09-05 11:01:15.983 MFF modify;UNIX.group;UNIX.mode; < 2024-09-05 11:01:15.983 MFMT < 2024-09-05 11:01:15.983 MLST modify*;perm*;size*;type*;unique*;UNIX.group*;UNIX.groupname*;UNIX.mode*;UNIX.owner*;UNIX.ownername*; < 2024-09-05 11:01:15.983 PBSZ < 2024-09-05 11:01:15.983 PROT < 2024-09-05 11:01:15.984 RANG STREAM < 2024-09-05 11:01:15.984 REST STREAM < 2024-09-05 11:01:15.984 SIZE < 2024-09-05 11:01:15.984 SSCN < 2024-09-05 11:01:15.984 TVFS < 2024-09-05 11:01:15.984 UTF8 < 2024-09-05 11:01:15.984 211 End > 2024-09-05 11:01:15.984 CLNT WinSCP-release-6.3.4 < 2024-09-05 11:01:16.022 200 OK > 2024-09-05 11:01:16.022 OPTS UTF8 ON < 2024-09-05 11:01:16.061 200 UTF8 set to on < 2024-09-05 11:01:16.061 Script: Connected . 2024-09-05 11:01:16.061 Connected . 2024-09-05 11:01:16.062 -------------------------------------------------------------------------- . 2024-09-05 11:01:16.062 Using FTP protocol. . 2024-09-05 11:01:16.063 Doing startup conversation with host. < 2024-09-05 11:01:16.063 Script: Starting the session... . 2024-09-05 11:01:16.102 Server: ProFTPD 1.3.8b . 2024-09-05 11:01:16.141 Getting current directory name. . 2024-09-05 11:01:16.141 Startup conversation with host finished. < 2024-09-05 11:01:16.141 Script: Session started. < 2024-09-05 11:01:16.141 Script: Active session: [1] ftp-kassen@transfer.weydringer-strohte.de > 2024-09-05 11:01:16.142 Script: lcd N:\IT_Drink\Payback\test < 2024-09-05 11:01:16.144 Script: N:\IT_Drink\Payback\test > 2024-09-05 11:01:16.145 Script: cd /Payback/ . 2024-09-05 11:01:16.145 Changing directory to "/Payback/". . 2024-09-05 11:01:16.184 Getting current directory name. < 2024-09-05 11:01:16.223 Script: /Payback > 2024-09-05 11:01:16.223 Script: put -resumesupport=on *.json . 2024-09-05 11:01:16.229 Copying 1 files/directories to remote directory "/Payback" - total size: 83.366.098 . 2024-09-05 11:01:16.358 File: 'Test.json' [2024-04-13T12:16:51.187Z] [83366098] . 2024-09-05 11:01:16.669 Copying "Test.json" to remote directory started. . 2024-09-05 11:01:16.670 Starting upload of N:\IT_Drink\Payback\test\Test.json . 2024-09-05 11:02:20.801 Upload successful . 2024-09-05 11:02:20.801 Transfer done: 'Test.json' => '/Payback/Test.json' [83366098] . 2024-09-05 11:02:20.801 Copying finished: Transferred: 83.366.098, Elapsed: 0:01:04, CPS: 1.291.056/s > 2024-09-05 11:02:20.802 Script: close . 2024-09-05 11:02:20.815 Disconnected from server
