PutFiles (SFTP) to mainframe dataset
Good day.
I am able to put a file on a mainframe with the interface.
The output is a dataset.
Generated code is this:
This is the remote location I put in to put the file:
(As per the attachment.)
It works 100% with the GUI.
When trying the API, it puts the dataset on the default folder when using the API and not the actual dataset.
(Hope this makes sense.)
If someone can push me in the correct direction to configure the API to upload the local (Windows) file as a dataset on a mainframe?
Thank you
Mike
using (Session session = new Session()) { session.Open(sessionOptions); session.PutFiles(@"C:\temp\New Text Document.txt", "/FTADV:P=WIN,lrecl=160,recfm=fb/*").Check(); }
/FTADV:P=WIN,lrecl=160,recfm=fb/___SS.APP.TEST.SOLMIS.CIF856
Thank you
Mike
