Invalid access to memory - TTerminal::GetIsCapable
Goto page
Previous, 1, 2, 3, 4, 5, 6, 7
yoshia0305@...
WinSCP 5.13.4
(007B9D16) TTerminal::GetIsCapable
(0007DAFF) ntdll.dll
(003C2F1C) System::Actions::TContainedActionList::UpdateAction
(001A8CB2) Vcl::Actnlist::TCustomAction::Update
(0021AB1A) Vcl::Forms::_16777
(0021AB98) Vcl::Forms::TCustomForm::UpdateActions
speddy20537@...
Zugriffsverletzung - ungültiger Zugriff auf den Speicher - TTerminal::GetIsCapable
WinSCP 5.14
(007EB279) TTerminal::GetIsCapable
(008F9532) C5107_0
(008FB59A) ____ExceptionHandler
(008F8354) __ExceptionHandler
mikecalabrese@...
The program lost the connection. I went to close it and got the error.
WinSCP 5.13.4
(0006248E) ntdll.dll
nikhilsoragavi@...
WinSCP 5.13.3
(007B8B82) TTerminal::GetIsCapable
(00081D3F) ntdll.dll
(0006F8BA) ntdll.dll.KiUserExceptionDispatcher
(003C256C) System::Actions::TContainedActionList::UpdateAction
(001A8302) Vcl::Actnlist::TCustomAction::Update
(0021A16A) Vcl::Forms::_16777
(0021A1E8) Vcl::Forms::TCustomForm::UpdateActions
Re: Zugriffsverletzung - ungültiger Zugriff auf den Speicher - TTerminal::GetIsCapable
speddy20537@... wrote:
WinSCP 5.14
(008F9532) C5107_0
it@... wrote:
happens when cancelling a connection while establishing before timeout.
WinSCP 5.14.1
(007EBEA1) TTerminal::GetIsCapable
(008FA2C6) C5107_3
(008FC32E) ____ExceptionHandler
(008F90E8) __ExceptionHandler
(0008341F) ntdll.dll
diver@...
WinSCP 5.13.4
martin.larsson2@...
Ogiltig åtkomst till minnet - TTerminal::GetIsCapable
WinSCP 5.13.4
Stackspår:
while pressing abort on a connection that wasent working (I think)
Ogiltig åtkomst till minnet.
Stackspår:
ehlmann@...
WinSCP 5.13.4
mdavis@...
WinSCP 5.13.2
(007B89D2) TTerminal::GetIsCapable
(003C2428) System::Actions::TContainedActionList::UpdateAction
(001A81BE) Vcl::Actnlist::TCustomAction::Update
(0021A026) Vcl::Forms::_16777
(0021A0A4) Vcl::Forms::TCustomForm::UpdateActions
bcomsugi@...
WinSCP 5.13.4
(00062496) ntdll.dll
ddejordy@...
WinSCP 5.13.4
mpz11@...
WinSCP 5.13.3
(0007DA8F) ntdll.dll
domingueznancy13@...
WinSCP 5.13.4
Re: Ogiltig åtkomst till minnet - TTerminal::GetIsCapable
martin.larsson2@... wrote:
WinSCP 5.13.4
Stackspår:
Stackspår:
Re: Invalid access to memory - TTerminal::GetIsCapable
bcomsugi@... wrote:
WinSCP 5.13.4
peinfewpn2@...
WinSCP 5.13.1
(007B6942) TTerminal::GetIsCapable
(00089B5F) ntdll.dll
(003C0F5C) System::Actions::TContainedActionList::UpdateAction
(001A6CF2) Vcl::Actnlist::TCustomAction::Update
(00218B5A) Vcl::Forms::_16777
(00218BD8) Vcl::Forms::TCustomForm::UpdateActions
er.abgupta@...
WinSCP 5.13.4
ionut.cioflan@...
WinSCP 5.14.1
(007EBEA1)
(008FA2C6)
(008FC32E)
(008F90E8)
dianareider@...
When an SSH connection times out, WinSCP asks for username again to reconnect (as expected). However, if you do not attempt to reconnect but instead close the connection, it returns this error that repeats every time you click OK. If you continue to click OK, you receive a message that a call to an OS function has failed and Windows eventually pops up a message (after a few dozen clicks) that the client has stopped working and to kill task. Otherwise I can end via Task Manager.
WinSCP 5.13.4
star@...
This happens when I try to cancel a connection that is not connecting.
WinSCP 5.14.1
(008FA2C6) C5107_3
fgdsga
无效的内存访问。 - TTerminal::GetIsCapable
WinSCP 5.13.2
无效的内存访问。
josemonva@...
WinSCP 5.13.1
(00085B2F) ntdll.dll
ctb43@...
WinSCP 5.13.4
josemonva@... wrote:
WinSCP 5.13.1
WinSCP 5.13.4
WinSCP 5.14.1
(008FA2C6) C5107_3
jukka@...
This happens when I leave my connection open overinight. At some point server has disconnected, and this error message popups just keep on popping up. I need to use Task Manager to kill WinSCP in order to get error message popups closed.
WinSCP 5.13.4
a.s.lyulina@...
WinSCP 5.13.4
ctb43@...
WinSCP 5.13.4
kuiperix@...
Belleğe hatalı erişim - TTerminal::GetIsCapable
WinSCP 5.13.4
Belleğe hatalı erişim.
Yığın izleme:
(0007DABF) ntdll.dll
tab169@...
WinSCP 5.13.3
t-terasawa@...
メモリのアクセス違反 - TTerminal::GetIsCapable
WinSCP 5.14.1
メモリのアクセス違反
スタック トレース:
(008FA2C6) C5107_3
seema.bhandary@...
WinSCP 5.13.4
coolwav@...
WinSCP 5.13.4
Description: unable to close WINSCP
davidgalperin99@...
WinSCP 5.13.4
tphiman@...
Accès mémoire invalide - TTerminal::GetIsCapable
WinSCP 5.13.4
Accès mémoire invalide.
Trace de la pile :
(00081D0F) ntdll.dll
salsero@...
Acceso a memoria no válido - TTerminal::GetIsCapable
WinSCP 5.13.3
Traza de la pila:
sca432@...
WinSCP 5.13.3
howard.coons@...
I connect to a server. I transfer a file. WinSCP times out after sitting idle for a certain period of time. I close WinSCP. This error appears.
WinSCP 5.13.4
gaofx2006@...
WinSCP 5.13.3
无效的内存访问。
(00081CFF) ntdll.dll
(0006F87A) ntdll.dll.KiUserExceptionDispatcher
WinSCP 5.13.4
Re: Belleğe hatalı erişim - TTerminal::GetIsCapable
kuiperix@... wrote:
WinSCP 5.13.4
Yığın izleme:
Re: メモリのアクセス違反 - TTerminal::GetIsCapable
t-terasawa@... wrote:
WinSCP 5.14.1
メモリのアクセス違反
スタック トレース:
(008FA2C6) C5107_3
Re: Acceso a memoria no válido - TTerminal::GetIsCapable
salsero@... wrote:
WinSCP 5.13.3
Traza de la pila:
sca432@... wrote:
WinSCP 5.13.3
WinSCP 5.13.4
pgoncharova@...
WinSCP 5.13.4
akrutsinger@...
Up front, this is the first time I've come across this error so I apologize that I cannot provide more detailed steps or speak intelligently about whether it can be reproduced or not. I still want to send this at a minimum for your awareness awareness.
Here is what happened prior to this error occurring though:
- Logged in to a remove server
- Laptop went to sleep (thus the connection was lost)
- Woke up my laptop and WinSCP prompted for me to re-enter my password for the server I was previously logged into
- I clicked the "X" to close out the login window and WinSCP crashed.
- Additionally, Whether I click "OK" or the "X" to close the Error report dialog continues to pop up this same error dialog. I had to kill the WinSCP process
WinSCP 5.13.4
fakoff@...
Érvénytelen memóriaelérés - TTerminal::GetIsCapable
WinSCP 5.13.4
Veremkivonat:
(00052DD6) ntdll.dll
cstan-geo@...
WinSCP 5.13.3
(0007CD1F) ntdll.dll
waiyanan.g@...
WinSCP 5.13.4
メモリのアクセス違反
スタック トレース:
ignatoana94@...
WinSCP 5.13.2
reethesh.reddy914@...
WinSCP 5.13.2
y.nedjar@...
WinSCP 5.13.4
Trace de la pile :
mikey219@...
WinSCP 5.13.4
shahid.abbasi@...
WinSCP 5.13.4
jweathe@...
WinSCP 5.13.3
mail@...
This error happens if I click the close button of the connect window when WinSCP is still trying to connect to the server..
WinSCP 5.14
(007EB279)
(008F9532)
(008FB59A)
(008F8354)
ionut.cioflan@...
WinSCP 5.14.1
(007EBEA1)
(008FA2C6)
(008FC32E)
(008F90E8)
sfslug@...
WinSCP 5.14.1
(008FA2C6) C5107_3
(00082DFF) ntdll.dll
dien.harry@...
WinSCP 5.14.1
Trace de la pile :
(008FA2C6) C5107_3
Using a Jailbroken Kindle in RDNIS mode. Accessing his memory through sftp as root with no password at 192.168.15.244 (my own PC adress on the Kindle netword ; Kindle creates a 192.168.15.1 network adapter). Disconnecting the kindle from the computer by removing the USB capable.
WinSCP loses the connection, and tries to reconnect to a non existent IP address on a non existent network. When I hit the close button of the auto-reconnect dialog, crashes.
Happens every time.
alba.beltran@...
WinSCP 5.13.4
Traza de la pila:
ikaneko@...
WinSCP 5.14.1
メモリのアクセス違反
スタック トレース:
(008FA2C6) C5107_3
(000836DF) ntdll.dll
Re: Accès mémoire invalide - TTerminal::GetIsCapable
@dien.harry: Thanks for your report.
@ionut.cioflan: Thanks for your report.
odia_ukoko@...
WinSCP 5.19.2
(00DC024C) TTerminal::GetIsCapable
(0008788F) ntdll.dll
(00050EC8) TScpCommanderForm::CopyParamDialog
(0000FF0B) TCustomScpExplorerForm::ExecuteCopyMoveFileOperation
(00010C88) TCustomScpExplorerForm::ExecuteFileOperation
(0002A871) TCustomScpExplorerForm::DoOperationOnFoundFiles
(0002A94A) TCustomScpExplorerForm::DoDownloadFoundFiles
(00E13E48) TFileFindDialog::FileListOperation
(00E142C8) TFileFindDialog::DownloadActionExecute
(00280255) Vcl::Controls::TWinControl::WndProc
(001E83E4) Vcl::Stdctrls::TButtonControl::WndProc
(002803BB) Vcl::Controls::_17076
(0023A71C) Vcl::Forms::TCustomForm::WndProc
dambas.ss@...
The error is very easy to reproduce. It is enough to get the "Access denied" window by entering the wrong password when connecting to the FTP server, and at the same time save the file in an open editor.
Steps:
  1. Connect to any FTP server and open file from WinSCP session in any editor.
  2. Connect to any FTP server, but, set wrong password before connected.
  3. Get error window, and don't close it (image in post)
  4. Open editor, put some symbols, and save him.
  5. Get error and exception
WinSCP 5.21.2
(00DD2728) TTerminal::GetIsCapable
(00FD296E) C5412_0
(00FD49D6) ____ExceptionHandler
(00FD1790) __ExceptionHandler
(00087B7F) ntdll.dll
(00076FD5) TEditorManager::CheckFileChange
(00074D75) TEditorManager::Check
(00019B69) TCustomScpExplorerForm::Idle
(0004D143) TNonVisualDataModule::DoIdle
(0004D100) TNonVisualDataModule::SessionIdleTimerTimer
(003CA660) System::Classes::_18201
(00040379) USER32.dll
(00037335) USER32.dll
(00035095) USER32.dll
(00FD2FD9) C5412_0
(00FD45B3) _ReThrowException
(00077015) TEditorManager::CheckFileChange
Description: dont close this window for get error
@dambas.ss: Thanks for your report.
sales@...
WinSCP 6.3.4
(00C62320) TTerminal::GetIsCapable
(00E22DAE) C6612_0
(00E21BD0) __ExceptionHandler
(0008818F) ntdll.dll
@sales: Thanks for your report.
Goto page
