Cannot change Visible in OnShow or OnHide - Vcl::Forms::TCustomForm::CMShowingChanged
Goto page
Previous, 1, 2, 3
a.s.jernakov@...
WinSCP 5.17.4
Трассировка стека:
(00237E84) Vcl::Forms::TCustomForm::CMShowingChanged
(000281C3) TCustomScpExplorerForm::CMShowingChanged
(00028052) TCustomScpExplorerForm::Dispatch
(00279DF5) Vcl::Controls::TWinControl::WndProc
(002342BC) Vcl::Forms::TCustomForm::WndProc
(00E4137C) Vclcommon::C2992_0
a.s.jernakov@...
WinSCP 5.17.4
Трассировка стека:
info@...
WinSCP 5.17.4
jcarlson1701@...
<Try to describe precise steps that lead to the problem (where do you click, what keys do you press, what do you see, etc.)> Error dialog appears at launch of WinSCP
WinSCP 5.17.4
mattia.landoni@...
I just installed WinSCP on a fresh windows install. This message happens every time I open the program. The program then opens up and works regularly.
WinSCP 5.17.4
pivovarov.maxim@...
WinSCP 5.17.4
Трассировка стека:
scott.shapiro@...
Occurs when launching program after install on new laptop. Once I log into a site, I cannot navigate to directories. They are grayed out. My other laptop has 5.17.3 and I don't have an issue. I grabbed that version for my new laptop and I'm up and running on the older version.
WinSCP 5.17.4
rafatrelles17@...
WinSCP 5.17.4
402641605@...
WinSCP 5.17.4
karbuncle@...
Fresh install, on launch. Happens all the time. After clicking OK it seems to function normally.
WinSCP 5.17.4
yzu-vetlab@...
WinSCP 5.17.4
zgubacsi@...
Error occurs on every start of the application.
After continue the application works but the remote window is disabled (grey). No click event received by the panel.
WinSCP 5.17.4
Veremkivonat:
frankhoeflich@...
When starting WinSCP with local directory on my Windows 10 laptop, and remote directory on my Ubuntu server at work (via Cisco AnyConnect Secure Mobility Client VPN).
WinSCP 5.17.4
pushkin@...
WinSCP 5.17.4
darren.joyner@...
The errors happen when I open the program
WinSCP 5.17.4
wani_fakhira95@...
WinSCP 5.17.4
davec.bugs@...
WinSCP 5.17.4
fatuitycookie@...
WinSCP 5.17.4
nidhitewari23@...
WinSCP 5.17.4
wrnewcombe@...
WinSCP 5.17.4
msekiguc@...
WinSCP 5.17.4
スタック トレース:
Re: Cannot change Visible in OnShow or OnHide - Vcl::Forms::TCustomForm::CMShowingChanged
Thanks for your reports.
cedric.repincay@...
WinSCP 5.17.4
Trace de la pile :
johnnyv_cn@...
Error displayed when starting WinSCP.
WinSCP 5.17.4
mailingbin@...
WinSCP 5.17.4
Трассировка стека:
eboto@...
- installed with .exe file
- got a window with error
WinSCP 5.17.4
Trace de la pile :
jannette@...
WinSCP 5.17.4
liannedelange7@...
WinSCP 5.17.4
rafisoltys@...
WinSCP 5.17.4
amihai@...
WinSCP 5.17.4
m@...
WinSCP 5.17.4
(00237E84)
(000281C3)
(00028052)
(00279DF5)
(002342BC)
(00E4137C)
a.s.jernakov@...
WinSCP 5.17.5
(0025293B) Vcl::Forms::TCustomForm::CMShowingChanged
(00035533) TCustomScpExplorerForm::CMShowingChanged
(00034F37) TCustomScpExplorerForm::Dispatch
(001D6079) Vcl::Controls::TControl::WndProc
(001DBD17) Vcl::Controls::TWinControl::WndProc
(0024DD70) Vcl::Forms::TCustomForm::WndProc
(00FE78AB) Vclcommon::C3005_0
(00FEA8E0) DoFormWindowProc
(00FE7A64) Vclcommon::C3005_0
(001D5B7A) Vcl::Controls::TControl::Perform
(001DAFC0) Vcl::Controls::TWinControl::UpdateShowing
(001DB0E6) Vcl::Controls::TWinControl::UpdateControlState
(001DAE56) Vcl::Controls::TWinControl::CMRecreateWnd
(00034F85) TCustomScpExplorerForm::Dispatch
(00FEAB40) DoFormWindowProc
(001DAE0B) Vcl::Controls::TWinControl::RecreateWnd
(0024F352) Vcl::Forms::TCustomForm::SetPosition
(000DAD29) RestoreForm
(00062E3F) TScpCommanderForm::RestoreFormParams
(0002BD1A) TCustomScpExplorerForm::DoShow
(000642C2) TScpCommanderForm::DoShow
(00252994) Vcl::Forms::TCustomForm::CMShowingChanged
(001DE771) Vcl::Controls::TWinControl::CMVisibleChanged
(001D3CB0) Vcl::Controls::TControl::SetVisible
(0024D4AD) Vcl::Forms::TCustomForm::SetVisible
(00259B8D) Vcl::Forms::TApplication::Run
(0012A258) Execute
(0000315D) wWinMain
(0112F759) C5178_0
(00066C12) ntdll.dll.RtlGetAppContainerNamedObjectPath
(00066BDF) ntdll.dll.RtlGetAppContainerNamedObjectPath
Goto page
Previous, 1, 2, 3
