Invalid access to memory - TTerminalManager::TerminalQueryUser
Goto page
Previous, 1, 2
csipes@...
WinSCP 5.17.9
(000AD42F) TTerminalManager::TerminalQueryUser
(0008244F) ntdll.dll
(0006FFAA) ntdll.dll.KiUserExceptionDispatcher
(00CC4069) TQueryUserAction::Execute
(00CC0A65) TQueueItemProxy::ProcessUserAction
(00018E8A) TCustomScpExplorerForm::UserActionTimer
(0025177B) Vcl::Extctrls::TTimer::Timer
(0002C2D1) USER32.dll
(0000C305) USER32.dll
(0000BC4F) USER32.dll
Re: Invalid access to memory - TTerminalManager::TerminalQueryUser
chris wrote:
Martin,
Thank you for your response, I was able to determine the issue was related to the disk quota for the uploads directory on the sftp server.
I contacted the administrator and requested an increase of allocated space and the uploads were able to be completed successfully.
It may be useful for others to post in the FAQs or knowledge base, is there one available that I may add the resolution to?
Thanks!
Chris Sipes
Advanced Solutions, Inc.
| Software & Systems Engineering
| csipes@go-asi.com
| office 303.979.2417 x131
| mobile 303.882.1123
campolo@...
Accesso alla memoria non valido - TTerminalManager::TerminalQueryUser
Dear all,
I have to upload for each file I check and validate (max 10KB each).
This happens with a frequency of 2-3 times per minute.
Unfortunately, the disconnection problem recurs often, even every 10 minutes.
I enclose what the debug window reports.
Thanks and good job.
WinSCP 5.17.10
(000AD433) TTerminalManager::TerminalQueryUser
(000861AF) ntdll.dll
(00CC41E1) TQueryUserAction::Execute
(00CC0BDD) TQueueItemProxy::ProcessUserAction
(0025179F) Vcl::Extctrls::TTimer::Timer
(0003DF59) USER32.dll
(00034EC5) USER32.dll
(00032C35) USER32.dll
Re: Accesso alla memoria non valido - TTerminalManager::TerminalQueryUser
joao-fp@...
Acesso inválido à memória - TTerminalManager::TerminalQueryUser
WinSCP 5.17.9
Rastreamento de pilha:
(0008627F) ntdll.dll
(00072C01) ntdll.dll.KiUserExceptionDispatcher
cedric@...
Accès mémoire invalide - TTerminalManager::TerminalQueryUser
WinSCP 5.17.9
Accès mémoire invalide.
Trace de la pile :
(00088F2F) ntdll.dll
(000437A9) USER32.dll
(000242A7) USER32.dll
(000233F9) USER32.dll
yash.hot7@...
WinSCP 5.17.10
w_i_n_s_c_p_net@...
Set up a very long SFTP transfer on a ethernet cable that's 400mbit limited. Suspect that it's a buffer overflow. Bug seems triggered when high-rate transfers happen ~37MByte/s
WinSCP 5.17.10
(00088F4F) ntdll.dll
(000743E1) ntdll.dll.KiUserExceptionDispatcher
max.slay89@...
Ошибка доступа к памяти - TTerminalManager::TerminalQueryUser
WinSCP 5.17.9
Ошибка доступа к памяти.
Трассировка стека:
(00006831) USER32.DLL.CallNextHookEx
(00006A95) USER32.DLL
(00008889) USER32.DLL
(000088EC) USER32.DLL.DispatchMessageW
mattwarrillow@...
WinSCP 5.17.6
(000AD1D7) TTerminalManager::TerminalQueryUser
(0008776F) ntdll.dll
(00073E91) ntdll.dll.KiUserExceptionDispatcher
(00CC1FA1) TQueryUserAction::Execute
(00CBE99D) TQueueItemProxy::ProcessUserAction
(00018E76) TCustomScpExplorerForm::UserActionTimer
(002508EF) Vcl::Extctrls::TTimer::Timer
(0003DEB9) USER32.dll
(00034E75) USER32.dll
(00032BE5) USER32.dll
david20fifa@...
Acceso a memoria no válido - TTerminalManager::TerminalQueryUser
WinSCP 5.19
Traza de la pila:
(000B18FF) TTerminalManager::TerminalQueryUser
(000878AF) ntdll.dll
(00CF06B5) TQueryUserAction::Execute
(00CECF65) TQueueItemProxy::ProcessUserAction
(000192C2) TCustomScpExplorerForm::UserActionTimer
(00256B3F) Vcl::Extctrls::TTimer::Timer
(003C7838) System::Classes::_18201
Re: Acceso a memoria no válido - TTerminalManager::TerminalQueryUser
document.control1@...
WinSCP 5.19.2
(000B192B) TTerminalManager::TerminalQueryUser
(0008788F) ntdll.dll
(00CF0FFD) TQueryUserAction::Execute
(00CED8AD) TQueueItemProxy::ProcessUserAction
(000192CE) TCustomScpExplorerForm::UserActionTimer
(00256CDF) Vcl::Extctrls::TTimer::Timer
(0003DDE9) USER32.dll
(00034DA5) USER32.dll
(00032B15) USER32.dll
(000328DB) USER32.dll.DispatchMessageW
djkdimi@...
WinSCP 5.19.2
Trace de la pile :
(00041BFE) ntdll.dll.RtlRaiseStatus
(00041A86) ntdll.dll.KiUserExceptionDispatcher
(000068E5) USER32.DLL
(00006A47) USER32.DLL
(00007D07) USER32.DLL
(000082EE) USER32.DLL.DispatchMessageW
Re: Accès mémoire invalide - TTerminalManager::TerminalQueryUser
@djkdimi: Thanks for your report.
williamsb2@...
WinSCP 5.19.5
(000B1A83) TTerminalManager::TerminalQueryUser
(00088F9F) ntdll.dll
(000741F1) ntdll.dll.KiUserExceptionDispatcher
(00CF8551) TQueryUserAction::Execute
(00CF4E01) TQueueItemProxy::ProcessUserAction
(00019342) TCustomScpExplorerForm::UserActionTimer
(00256E6B) Vcl::Extctrls::TTimer::Timer
(00043719) USER32.dll
(00024257) USER32.dll
(000233A9) USER32.dll
(0002318B) USER32.dll.DispatchMessageW
udayp6955@...
WinSCP 5.19.2
(00042399) USER32.dll
(00039335) USER32.dll
(00037095) USER32.dll
@williamsb2: Thanks for your report.
kacper.rucinski@...
WinSCP 5.19.5
(000975BF) ntdll.dll
(00075CA1) ntdll.dll.KiUserExceptionDispatcher
(00046DD0) USER32.dll
(00026275) USER32.dll
(00024BA3) USER32.dll
phin.pope@...
WinSCP 5.19.6
(00CF8CB5) TQueryUserAction::Execute
(00CF5565) TQueueItemProxy::ProcessUserAction
(00040099) USER32.dll
(00037055) USER32.dll
(00034DC5) USER32.dll
(00034B8B) USER32.dll.DispatchMessageW
mesiarm@...
Neplatný prístup do pamäte - TTerminalManager::TerminalQueryUser
WinSCP 5.19.6
Neplatný prístup do pamäte.
Trasa hromadenia
(00097AFF) ntdll.dll
(00076021) ntdll.dll.KiUserExceptionDispatcher
(00046CE0) USER32.dll
(00026195) USER32.dll
(00024AC3) USER32.dll
(000245FB) USER32.dll.DispatchMessageW
phil@...
WinSCP 5.19.6
(000980BF) ntdll.dll
(00078011) ntdll.dll.KiUserExceptionDispatcher
(00032051) USER32.dll
(00022DD1) USER32.dll
(00021690) USER32.dll
(000211DB) USER32.dll.DispatchMessageW
aaron.freeman@...
WinSCP 5.19.6
(0008786F) ntdll.dll
(000401F9) USER32.dll
(000371C5) USER32.dll
(00034F25) USER32.dll
@aaron.freeman: Thanks for your report.
wafranyofl@...
Unzulässiger Zugriff auf einen Speicherbereich - TTerminalManager::TerminalQueryUser
WinSCP 5.21.3
Stapelverfolgung:
(000B499B) TTerminalManager::TerminalQueryUser
(00CFD1F5) TQueryUserAction::Execute
(00CF9AA5) TQueueItemProxy::ProcessUserAction
(0001A2DA) TCustomScpExplorerForm::UserActionTimer
(00258F03) Vcl::Extctrls::TTimer::Timer
mobilekid@...
WinSCP 5.21.5
Трассировка стека:
(000B49AB) TTerminalManager::TerminalQueryUser
(00087AFF) ntdll.dll
(00D07871) TQueryUserAction::Execute
(00D04121) TQueueItemProxy::ProcessUserAction
(00258F13) Vcl::Extctrls::TTimer::Timer
(0003FBC9) USER32.dll
(00036B85) USER32.dll
(000348F5) USER32.dll
(000346BB) USER32.dll.DispatchMessageW
Re: Ошибка доступа к памяти - TTerminalManager::TerminalQueryUser
@mobilekid: Thanks for your report.
rmarquessanchez@...
Acesso à memória inválido - TTerminalManager::TerminalQueryUser
WinSCP 5.21.7
Acesso à memória inválido.
(000B49DF) TTerminalManager::TerminalQueryUser
(0009750F) ntdll.dll
(000777E1) ntdll.dll.KiUserExceptionDispatcher
(00D07A21) TQueryUserAction::Execute
(00D042D1) TQueueItemProxy::ProcessUserAction
(0001A2E2) TCustomScpExplorerForm::UserActionTimer
(00258F47) Vcl::Extctrls::TTimer::Timer
(000321D1) USER32.dll
(00022FA1) USER32.dll
(00021860) USER32.dll
(000213AB) USER32.dll.DispatchMessageW
jaroslaw.kiser@...
Nieprawidłowy dostęp do pamięci - TTerminalManager::TerminalQueryUser
WinSCP 5.21.7
(00087ACF) ntdll.dll
(00040399) USER32.dll
(00037365) USER32.dll
(000350D5) USER32.dll
Re: Nieprawidłowy dostęp do pamięci - TTerminalManager::TerminalQueryUser
@jaroslaw.kiser: Thanks for your report.
matthew.w.fearnley@...
I'm not sure exactly how it happened, but it was after an SFTP host stopped responding in the background, and trying to close various dialog boxes.
No logs, sorry.
WinSCP 6.1.1
(000BEE0B) TTerminalManager::TerminalQueryUser
(0009783F) ntdll.dll
(00D21711) TQueryUserAction::Execute
(00D1DF6D) TQueueItemProxy::ProcessUserAction
(0001BB4E) TCustomScpExplorerForm::UserActionTimer
(003CCDAF) Vcl::Extctrls::TTimer::Timer
(000313B1) USER32.dll
(000221B1) USER32.dll
(00020A70) USER32.dll
(000205BB) USER32.dll.DispatchMessageW
stephenglynn@...
On an unreliable internet connection (WiFi on a train) it kept trying to reconnect, so I hit Cancel. then Reconnect. The error appeared then. Not happened before.
WinSCP 6.1.1
alexander.demyashev@...
WinSCP 6.1.2
Трассировка стека:
(000BF6BF) TTerminalManager::TerminalQueryUser
(00D21FD1) TQueryUserAction::Execute
(00D1E82D) TQueueItemProxy::ProcessUserAction
(003CD663) Vcl::Extctrls::TTimer::Timer
(000080CC) USER32.DLL
(0000966A) USER32.DLL
calperin@...
WinSCP 6.1.2
(00031941) USER32.dll
(00022731) USER32.dll
(00020FF0) USER32.dll
(00020B3B) USER32.dll.DispatchMessageW
@calperin: Thanks for your report.
ryolee@...
無效的存取記憶體 - TTerminalManager::TerminalQueryUser
WinSCP 6.1.2
無效的存取記憶體
Stack 追蹤:
(00087A7F) ntdll.dll
(000401A9) USER32.dll
(00037165) USER32.dll
(00034C8B) USER32.dll.DispatchMessageW
cmartin@...
WinSCP 5.21.7
Traza de la pila:
(00040209) USER32.dll
rafal.wysoglad@...
WinSCP 6.1.2
muhammadqasim@...
WinSCP 6.3.3
(000C3907) TTerminalManager::TerminalQueryUser
(00087A6F) ntdll.dll
(00B7E395) TQueryUserAction::Execute
(00B7AC19) TQueueItemProxy::ProcessUserAction
(0001C862) TCustomScpExplorerForm::UserActionTimer
(003DFF67) Vcl::Extctrls::TTimer::Timer
(002271BC) System::Classes::_18201
(00040779) USER32.dll
(00036B65) USER32.dll
(0003549C) USER32.dll
(00034FBB) USER32.dll.DispatchMessageW
ankit.sharma@...
WinSCP 6.3.4
(00098CCF) ntdll.dll
(00B7EA69) TQueryUserAction::Execute
(00B7B2ED) TQueueItemProxy::ProcessUserAction
(003DFB03) Vcl::Extctrls::TTimer::Timer
(000324C1) USER32.dll
(00023311) USER32.dll
(00021BB0) USER32.dll
(000216FB) USER32.dll.DispatchMessageW
rstylerm@...
WinSCP 6.3.4
Трассировка стека:
(00087FFF) ntdll.dll
(00040719) USER32.dll
(00036E85) USER32.dll
(000357BC) USER32.dll
(000352DB) USER32.dll.DispatchMessageW
cp@...
WinSCP 6.3.5
(000B029F) ntdll.dll
(0007AB8A) ntdll.dll.KiUserExceptionDispatcher
(00B800D1) TQueryUserAction::Execute
(00B7C955) TQueueItemProxy::ProcessUserAction
(000350A1) USER32.dll
(00023748) USER32.dll
(00022BD5) USER32.dll
(0002273B) USER32.dll.DispatchMessageW
alma.gideoni@...
WinSCP 6.3.6
(000C394F) TTerminalManager::TerminalQueryUser
(00098E4F) ntdll.dll
(00B80189) TQueryUserAction::Execute
(00B7CA0D) TQueueItemProxy::ProcessUserAction
(0001C8A2) TCustomScpExplorerForm::UserActionTimer
(003DFB4B) Vcl::Extctrls::TTimer::Timer
(00226F74) System::Classes::_18201
(000322D1) USER32.dll
(000230C1) USER32.dll
(00021980) USER32.dll
(000214CB) USER32.dll.DispatchMessageW
@alma.gideoni: Thanks for your report.
monica.haut@...
Hello - I was in the processing of downloading files that our former payroll service (ADP) had extracted to WinSCP for us. There were 23 zip files and I started the process of downloading all 'in the background'. When I went to check on the download process, I found that only 18 of the 23 zip files loaded. It looks like the download stopped due to ‘inactivity’??
I re-logged in to WinSCP – however – when I opened the ADP folder, there was only one zip file showing. I tried to download it and at first it looked like all was going well but it did not go through. When I tried to select download again, here is the message box I see. Not sure what happened to the rest of the zip files. Can you tell?
Screenshots attached. Thx for your help!
WinSCP 6.3.6
(00087F7F) ntdll.dll
(00074501) ntdll.dll.KiUserExceptionDispatcher
@monica.haut: Are you able to reproduce the problem? The files were probably meanwhile deleted from the server. Or doesn't the server automatically delete the downloaded files?
takimoto@...
メモリのアクセス違反 - TTerminalManager::TerminalQueryUser
WinSCP 6.3.4
メモリのアクセス違反
スタック トレース:
(000B0C7F) ntdll.dll
(0007ABCA) ntdll.dll.KiUserExceptionDispatcher
(00036DD1) USER32.dll
(00025448) USER32.dll
(000248D5) USER32.dll
(0002443B) USER32.dll.DispatchMessageW
Goto page
Previous, 1, 2
