Cannot focus a disabled or invisible window - Vcl::Forms::TCustomForm::SetActiveControl
Goto page
Previous, 1, 2
scrocker@...
This happened when connecting remotely to an NVIDIA Jetson computer. I had a remote session connected using PuTTY which was lagging at the time.
WinSCP 6.3.3
(003C5D0A) Vcl::Forms::TCustomForm::SetActiveControl
sidharthmudgil225@...
WinSCP 6.3.4
(003C594E) Vcl::Forms::TCustomForm::SetActiveControl
Re: Cannot focus a disabled or invisible window - Vcl::Forms::TCustomForm::SetActiveControl
@sidharthmudgil225: Thanks for your report.
gauravsingh.8026@...
WinSCP 6.1.2
(003B3406) Vcl::Forms::TCustomForm::SetActiveControl
jparker85302@...
I cannot determine the cause for this error
I updated to 6.3.5 and this error began being displayed.
I am running
Edition Windows 11 Home
Version 23H2
Installed on ‎8/‎24/‎2024
OS build 22631.4169
Experience Windows Feature Experience Pack 1000.22700.1034.0
Device name Acerswiftgo_14
Processor 13th Gen Intel(R) Core(TM) i7-13700H 2.40 GHz
Installed RAM 16.0 GB (15.7 GB usable)
Device ID 31B81D89-FCF7-4647-8272-858B31338E41
Product ID 00342-21151-85512-AAOEM
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
WinSCP 6.3.5
@jparker85302: Thanks for your report.
ansh167761@...
WinSCP 6.3.5
kcannon76@...
WinSCP 6.3.5
@kcannon76: Thanks for your report.
marco@...
WinSCP 6.4.1
Stapelverfolgung:
(004A5D82) Vcl::Forms::TCustomForm::SetActiveControl
nodrance@...
i was alt tabbing around, took a screenshot, sent it in slack, back to winscp, tried to move from a/b/c to a/b/d using the right side, and got an error, then it asked me to reconnect. I was connecting through a vpn if that makes a difference. Probably a weird edge case, alt tab is definitely involved.
Idk where to find the session log sorry
WinSCP 6.3.4
nodrance@...
Same person as before talking about alt tabbing
I think I might be able to reproduce this now
WinSCP 6.3.4
@nodrance: Thanks for your report.
rickdees78@...
WinSCP 6.5.3
(004A9B8E) Vcl::Forms::TCustomForm::SetActiveControl
martin@...
WinSCP 6.5.3
Rastreamento de pilha:
ssutherland@...
Clicked on open WinSCP window that I know had gone inactive (computer went to Sleep in meantime.) But since WinSCP screen was still open and displaying the right pane as I had left it connected some hours ago, I left-clicked in the right pane window expecting to be presented with either question if I wanted to log into this same server or to be presented with the Site Manager to select a site. (trying to remember if I left-clicked on the right pane's top window with the folders, or in the bottom windows showing the file contents of that highlighted folder. Reasonably sure that it was the right pane's Top Window with intention to go to another Folder (in case WinSCP still had an active connection to that displayed ftp server)
WinSCP 6.5.6
(004A9CA6) Vcl::Forms::TCustomForm::SetActiveControl
rahul.kumar@...
WinSCP 6.5.6
@rahul.kumar: Thanks for your report.
rohit.461@...
WinSCP 6.6.2
(004D582F) Vcl::Forms::TCustomForm::SetActiveControl
(004D5957) Vcl::Forms::TCustomForm::FocusControl
(003D2316) Vcl::Controls::TWinControl::SetFocus
(00527E4E) Pathlabel::TCustomPathLabel::Click
(003CA9C3) Vcl::Controls::TControl::WMLButtonUp
(003C9FB6) Vcl::Controls::TControl::WndProc
(0014748A) KERNELBASE.dll.CloseHandle
(000782AA) ntdll.dll.ZwClose
(001474A1) KERNELBASE.dll.CloseHandle
(000794DF) msvcrt.dll._vsnwprintf_l
(00108A76) combase.dll
(0001EC25) OLEAUT32.DLL
(0006049F) Msctf.dll
(00060093) Msctf.dll
(003C9BEC) Vcl::Controls::TControl::Perform
(003CE991) Vcl::Controls::TWinControl::IsControlMouseMsg
(003CEFA6) Vcl::Controls::TWinControl::WndProc
(0003A5C4) Msctf.dll.TF_Notify
(003CE66C) Vcl::Controls::TWinControl::MainWndProc
(00234FE0) System::Classes::_18364
(00038771) USER32.dll
(00027928) USER32.dll
(00027613) USER32.dll
(0007820A) ntdll.dll.ZwCallbackReturn
(00032FEE) USER32.dll
(000268F5) USER32.dll
(0003165C) USER32.dll.PeekMessageW
(0002645B) USER32.dll.DispatchMessageW
(004DD6D3) Vcl::Forms::TApplication::ProcessMessage
(004DD716) Vcl::Forms::TApplication::HandleMessage
(004DDA55) Vcl::Forms::TApplication::Run
(0015968E) Execute
(00027F0F) ntdll.dll
(00026BC3) UXTHEME.DLL
(0002A321) USER32.dll
(0002A2FC) USER32.dll
(000AE708) ntdll.dll
(004DC58D) Vcl::Forms::_17039
(004DCDF3) Vcl::Forms::TApplication::WndProc
(00027A32) USER32.dll
(000279C2) USER32.dll
(00027A29) USER32.dll
(0001578E) KERNEL32.DLL.GetProcAddress
(00028A87) USER32.dll
(00004395) wWinMain
(00BF8611) TDesktopFontManager::TDesktopFontManager
(0004742B) ntdll.dll.RtlInitializeCriticalSectionEx
(00166AD8) System::GetMem
(00169E96) System::NewUnicodeString
(0016AFCF) System::UStrSetLength
(0016B017) System::UStrCat
(00061A2D) ntdll.dll.RtlInitializeCriticalSection
(00093766) ntdll.dll
(00052334) ntdll.dll.RtlLeaveCriticalSection
(00C79FAA) __unlock_nt
(002EB4CC) System::Syncobjs::TCriticalSection::TCriticalSection
(00C77E05) C7739_0
(000A6A27) C13_7
(00C7943C) __init_exit_proc
(00C79785) __wstartup
(00014D47) KERNEL32.DLL.BaseThreadInitThunk
(0006C839) ntdll.dll
(0006C7BC) ntdll.dll
@rohit.461: Thanks for your report.
bakhtoarusmonov@...
WinSCP 6.5.6
Трассировка стека:
Goto page
Previous, 1, 2
