Upload My Web Site
This guide contains simplified description of uploading and editing your website with WinSCP.
Managing website differs greatly with webhosting provider. This article just summarizes basics you need to know to edit pages on your website or to upload new pages.
- Before Starting
- Web Site Directory
- File Names
- Uploading Pages
- Editing Pages
- Creating Pages
- Further Reading
Before Starting
Before starting you should:
Web Site Directory
Once you are connected, make sure you are in the remote directory dedicated to store a web pages. It may be the one you get in after logging in (it is the case if you do not see any subdirectories after logging in). But with some providers you will have several subdirectories available, from which only one is visible on the Internet. Such subdirectory will have a name like www, htdocs, httpdocs, public_html or other.
All files you upload to this directory will be visible on the Internet. So for example if you upload your page pictures.html into your web directory htdocs and your site domain is www.example.com, anyone will be able to see your page at address https://www.example.com/pictures.html.
By convention there is a single file that gets displayed if you do not specify any file in the address directly, i.e. frontpage. The name of the file is usually index.html or index.htm (or different extension if you use some scripting language).
File Names
Before you start uploading/creating pages, make sure you use reasonable file names. It is strongly recommended not to use punctuation characters, spaces and some special characters in filenames to be published on Internet. Hence instead of Mein Gästebuch.html, use mein_gastebuch.html.
Also URL (web addresses) are case sensitive, which is different to how Windows treat filenames. So if you first test your pages locally on Windows and links stops working once you upload the pages, it is probably for inconsistencies in letter cases. For example you may have a link to Mein_Gastebuch.html, but the file is actually named mein_gastebuch.html. This is not the same on Internet.
Uploading Pages
You may start uploading by dragging your files to remote panel of WinSCP. You can drag the files either from local panel (if you are using Commander interface) or from Windows File Explorer.
Read guide to upload files or full documentation of uploading files.
Editing Pages
If you do not need to maintain your files locally, you can edit them directly on the remote server.
Creating Pages
If you want to create the new page, either create new file locally and upload it. Or use Files > New > File command.
Further Reading
- Troubleshooting;
- Other guides to using WinSCP;
- Tasks you can do with WinSCP.
